Where to buy replacement 4.0 XJR engine?
WaterDragon (05-27-2013)
Go to CAR-PART.COM and follow search instructions. I searched for a 2000 XJR engine and found several for various prices. The best place on that list is LKQ but they are also with the priciest engine: $2785 for a 120k mile motor. ALL AUTO PARS and MAIN STREET AUTO DISMANTLERS selling theirs for $1600 ea. they are tested and have a 90 day warranty. Elite also lists an engine but ask to call for the price.
I would discourage from buying an engine from a private party, especially if you can't test it. Once you paid for it, it's yours even if it won't work. At least itch dismantlers you have some form of a warranty.
WaterDragon (05-28-2013)
I'd go for the 4.2 for the TS application.
Your search, then, has more options: the Range Rover Sport supercharged is also a Jag 4.2. Tho, The sump is bigger and it feeds to a 6 gear ZF, well as, the blower sits higher (the truck is much taller at bonnet). I was told the bearings are stronger than the ones used in Jags. The 05 LR3s also ran a Jag 4.2 (06 -09 ran Brit Ford 4.4s).
On the RRS forum look for a guy with Jaguar in his user name; a transplant living in LA with loads of experience on blown Jag engines.j
Andrew McVey
16
08-27-2015 07:21 PM
