Where can I buy part#1058-327-022
Hi jrb53,
If your 2000 X308 has the ZF 5HP24 transmission, I would think there would be many sources of the parts you need.
The Jaguar Daimler Heritage Trust lists the control valve and pressure regulators as still available:
Control Valve Assembly-3.2/4.0 Litre-V8 - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Heritage Parts UK
You could try jaguarmerriamparts.com, the Jaguar dealer in Merriam, Kansas, who sells Jaguar parts at discount prices.
Also, I would think that any transmission shop that repairs ZF gearboxes could help you (the same transmission was also used in many BMWs).
Here's the spare parts catalog:
http://www.zf.com/media/media/docume...sa_4/5HP24.pdf
And here's the repair manual:
http://www.jagrepair.com/images/Auto...r%20Manual.pdf
I hope this helps. By the way, how did you diagnose the problem with your valve body and pressure regulator?
Cheers,
Don
jrb53 (03-09-2015)
Thanks for the info .I had the transmission fluid and filter changed.before that every now and then I would get from 1st gear a thump on take off,which is now better than it was,after reading up on several threads on the subject I am getting pressure spikes which are related to worn regulator valve and body. so before I have to rebuild the transmission,I would change them as I could do it without having to removing the transmission. other than the spikes now and then the transmission shifts perfectly and runs like a dream. still I would like your input on that thought. thank you jrb53
It does sound like the valve body is worn. I have seen a repair kit in the past. It has a reamer and oversize valve, if I recall correctly. I have included a link to Sunbelt, a valve body rebuild service, but I have no experience of the quality of their work.
AW55-50, O1M, JF506E, 5R55e, 09G Valve Body ReplacementSunbelt Valve Body Builders
