Where do I begin? 2002 XJR
Hello Jag forum;
I have a 2002 XJR that is having multiple issues, and want some input from people whom may have come across the same issue. I had the check engine come on, scanned and found:
Code 128H/296 undocumented code
Erased code, and 2 days later code 128H/296 undocumented code returned.
I love this car! I have owned it for 6 months. Thus far, I have changed rear lower shock bushings, front lower ball joints, sway bar links, changed super charger oil, engine oil, alternator and supercharger belts, brake caliper pin bushings and one washer nozzle.
I have used the search bar on the top right, with and without google, tried google directly, identifix, and found nothing in all 4 areas!
Does this have to go to the dealer? What the heck is it?
You should try to find another code scanner than can communicate with Jaguar. Not sure exactly which one, but there are many members on here who have them.
Once you get one, read the codes and see what's logged and let us know what you find...
Do you get any specific warnings on the dash ( Restricted Performance, Engine Failsafe, Stability Control Fail, eg ) or just check engine light?
Any other symptoms - engine running rough, loss of power, etc..
Don B (01-25-2018)
No other specific warnings like the ones you mention. Once in a while, when I'm feeling frisky I will hammer it off the line. If I loose a bit of traction, the stability / ABS will kick in for a second. That's it.
I have other issues (security system is wonky, mirrors sometimes don't work) but this doesn't give me ANY hints of what it is and there is no mention of it anywhere! I did get B codes and P codes. This code- no B or P. 128H/296
Received 1,813 Likes
Don B (01-25-2018)
Don B (01-25-2018)
Don B (01-25-2018)
frombenz2jag
01-18-2008 02:40 PM
frombenz2jag
01-14-2008 02:59 AM
