Where to get this gasket? - RESOLVED
I have a 2002 XJ Sport. Already has the aluminum thermostat housing. A while back, I replaced the thermostat. The thermostat cover,(where upper radiator hose goes to) had a gasket but I broke it. So, I cut one using blue fel pro gasket maker. It started leaking at a very slow rate.
Without risking me cutting a bad gasket again, anyone know where I can get the gasket from? I have searched and searched. Yes, 100% sure that is where the leak is coming from.
Happy holidays everyone
Last edited by GGG; 12-28-2017 at 02:41 PM. Reason: Add "RESOLVED" to thread title
Non - Supercharger:
https://www.jaguarclassicparts.com/u...t-supercharged
Supercharged :
https://www.jaguarclassicparts.com/u...8-supercharged
Use the jaguar part # and see if one is closer maybe Welsh in Chicago , verify VIN # as I believe there is a changeover
Is there a difference between the metal and plastic housing ?
Don B (12-27-2017)
+1 to Lady P., Welsh is pretty good at having those kind of things. You may also want to try XKs Unlimited - Classic and Modern Jaguar Auto Parts Specialists since 1973, they've been good for those parts also and decently priced.
Don B (12-27-2017)
Item # 5 Jaguar # NCA2246BA for XJ8 Non - Supercharger ?
http://www.welshent.com/product_info.php?sku=NCA2246BA
https://www.oreillyauto.com/detail/u...2246ba/4772579
http://xks.com/i-7088863-jaguar-ther...%26go%3DSearch
Don B (12-27-2017)
Hi Brandon,
The thermostat and seal are common parts offered by most of the major suppliers (Waxstat, Stant, Gates, Motorad, Murray, Mahle, etc.). I've purchased them from local auto parts stores like NAPA and O'Reilly. If they don't have one in stock, they can typically get one within a day. If your stores can't get you one, any of our forum sponsors should be able to, including Welsh Enterprises, Coventry West, SNG Barratt, and Jagbits.
Cheers,
Don
Cheers,
Don
Highhorse (12-28-2017)
The parts break down do not appear to show a gasket, only ‘O’ rings. Are you sure that you require a gasket there? I can’t see why a manufacturer would use an ‘O’ ring and a gasket, one or the other normally.
Perhaps a PO thought it needed one? The extra thickness of a gasket may be holding the clamping force off the ‘O’ ring?
The following 3 users liked this post by avern1:
A added mating surface face gasket thickness dimension reduces the pinch of the inner seal # 5 . In the big picture , I would go without the phantom gasket . Just my opinion with no experience on this area of concern for whatever it is worth .
The Jaguar Whisper , Parker
Lagonia
03-03-2016 09:18 AM
1964Daimler
09-09-2015 11:20 AM
fliegenfischen
09-16-2014 03:07 AM
markusrap
07-19-2012 04:46 PM
