Hi unfortunately I have a problem the upper cooling fan connector melted for some reason
I did search on rock auto but couldn't find fan connector and the catalog doesn't have one too I'm not sure if other cars have same fan connector the only option I have is the junkyard so I hope someone know where to buy this connector
JAGUAR XJ SERIES X308 LEFT HAND FRONT HARNESS LINK LEAD LNF3125AA
If you just need the connector, it will have to be a salvage part.
Thank you, yup I just need the connector will get it from salvage parts . Any idea why the connector melted? All fuses are fine and relay working fine I'm thinking the fan itself may need replacement
Most likely the fan motor but, if at one time it was unplugged and not quite plugged back in all the way until it clicked, could’ve been a loose, dirty connection to have gotten hot.
Jaguar sells the fan as an ASSEMBLY.(cowl and fans)
I replaced dozens at the dealer but saved the individual fans when one failed.
I always checked the 'power-draw' and wrote the AMP required on the fan itself.
Most were in the 25 AMP category but some required 30 or more.
You can replace an individual fan but please note the power draw.
High AMP-DRAW will melt a connector!!!!!!!!!!!!!!
Didn't know it may need more than 30amp fuse !
Thanks for the info at some point I was thinking to install spal fan but the OEM cool the engine as it should
Somebody surely did well fitting them in the factory housing. I think the CFM output of those fans are just about halved though.
I wonder if jag had specs on the factory fans CFM wise…
Factory fans are very good at least for the xj8 I don't know for xjr but thankfully I don't see more than 210f AC on in hot day , however spal cooling fans is upgrade definitely higher CFM but not worth it for xj8 since it's NA and not high performance car . maybe good upgrade for the xjr adding 170f thermostat and external larger transmission cooler that helpful to keep it cool
Fan connector to Opel etc I'd say that will fit. But I certainly do not trust the cabling. Not even close as thick as it should. But can not be sure untill in hand.
I get that the Spal fans are an upgrade. The comment about the CFM halved was in reference to that there’s 3 fan cages for each of those fans and airflow is blocked. If I do go for a brushless fan setup, I may end up having to get a custom fan shroud made. I did an electric fan conversion on my wife’s 90’ 300ZX a few years ago and it’s still working great.
