Where to pry intake manifold?
I’ve double checked my guides, and I’m pretty sure that I have disconnected everything, and some that I didn’t need to.
all the guides I’ve found basically say lift it or wiggle. Mine doesn’t budge.
is this a safe spot? -passenger/right side
only mention that I can find, pertaining to this model, is prying on the aluminum thermostat housing. Guess I’ll try that…
Under the throttle body is an aluminum elbow going to the plastic manifold. That elbow has one 8mm bolt head on each side just above the front of the transmission. Make sure those are removed. You may also have to loosen two other bolts on each side of the lower elbow bracket as it pinches that elbow into place. Other than that, it should be loose.
Joe Enge (10-21-2022)
Hyrum Lindquist
08-10-2021 04:29 AM
The_Portuguese
02-06-2021 07:28 PM
