White Smoke? What is causing it?
I' getting a huge plume of white smoke every time I go to start my Jag. It's a 1999 XJR. I just recently replaced the fuel pump. I've been getting warning lights for "engine coolant low" however, when my mechanic checked all the fluids they were all fine.
After driving away the white smoke goes away. It's only on the initial start up and first mile or so that the white smoke comes out. The Jag also gives out an unpleasant smell and runs rough. A friend of mine told me it it had something to do with water or oil leaking in the engine? I also heard it might be a head gasket? I use synthetic oil and I heard that that will sometimes leak.
My question is what is causing this white smoke to come out? Also, what can I do to fix it?
Here is a link to a video of a start up with the white smoke coming out.
White smoke is heating / water related.
Water is getting on the pistons, hence head gasket, .... Could be condensation, .... Either way it's water in your engine.
The way it normally goes ....
White Smoke - Head Gasket
Blue Smoke - Piston Rings
Black smoke - To much fuel
Grey smoke - Perfect running
Hope this helps
Hope this helps
Have you had a check engine light? Any codes? If the engine is running rough now, it will get progressively worse over the next week. If no codes yet, they will likely start showing up as the engine runs more rough.
Sounds an aweful lot like a head gasket issue, which would require opening up the engine to replace the gasket(s), along with other 'while you're there' parts. Or, replace the engine with a newer, lower mileage unit (a path I just went down). Out of curiosity, is your mileage between 80-100k? Others more knowledgeable than me will chime in with ways to more definitively test for what is going on, ie, compression test, etc.
The correct way to fix the car is remove the heads and check for cracks. If the car has EVER been overheated it is very likely to be cracked or have a bad head gasket.
You don't have a lot to loose by trying Bars stop leak for head gaskets or blocks.
Using this WILL likely clog up your heater core and may not do any good, but in some
cases it will give you another year or two life from the engine.
A good used engine with warranty will run about $2,600 when it finally dies.
There are tests that show exhaust gas in the coolant to confirm a leaking head gasket.
