Will cylinder heads from a 1998 XJR fit a 2000 XJR
My 2000 XJR needs new heads, the car overheated and the heads warped, I found one for the right side on ebay from a 1998 xjr but don't know if it will fit my 2000. Are they the same? Any variations between model years? Any compatibility issues?
BobRoy (05-04-2018)
You don't need to go for "XJR" cylinder heads. Heads from XJ8 3.2, 4.0 or S-type 4.0 (not from any 4.2) are all the same as long as they carry numbers XR83-6C064-xx for left and XR83-6090-xx for right. It is actually better to look for heads from an NA engine as they would have been stressed less, especially if from a 3.2 XJ8.
If using a head from an NA engine, you only need to plug one oil passage at the front of each head for which you can get special rivets here: . The position of the hole to be plugged is shown in the attached bulletin which just shows the operation the other way around - removing the rivet.
The plugs are actually blind rivets. You need a heavy duty rivet gun to install them, i.e. a rivet gun which can take rivets having 3.5 mm pulling rod. Something like this:
BobRoy (05-04-2018)
WTB[SouthWest]: [CA] x308 XJR cylinder heads
OUScooby
08-08-2017 10:18 PM
jagosaurus
11-19-2013 04:15 PM
