Will a "failing" sensor cause a failed smog check?
I ran a test on my OBD2 on torque and received the following "Not Ok TID: $0a CID:$11". I saw somewhere else in this forum that a couple of people have received this code, and I
was just more concerned will it affect a smog test. The car runs great that is the only issue I can find with no other fault code beside P1111 which from my understanding is all systems are good. I have attached the torque results.
