window problem-jagjunky
jaguar 2000 xj long.......drivers side window won't come down (all other windows working fine)......looking at rubber around window (inside)....and suspect may have had work done to it prior to my obtaining car.....fortunately in up position all the way so no water getting in.
so of course its got to be the switch or window motor(s)....
when you press the window button for down.....makes a click and than another delayed click....but window will not move....when you hit the window switch for up....no noise at all......checked out all the security stuff to see if I accidently hit something to cause the window to stay in up position....but I think not....
looking for ideas suggestions before I take to my mechanic.....and does anyone know where I can pick up a window motor.....in the aftermarket....as I think that's what it is......
From my experience the hard reset will fix the problem but only temporarily for like two days or so. Checked the battery today and it is reading as good so that's not the problem either. Stripped down the drivers door, checked switches, wiring, and computer board and all look good as well. Hope you have better luck than me but at this point I'm thinking its the BPM. Good luck man
problem solved
the good news is the re-set worked.....sun roof also holds /works as it should.....now I know door motor is ok......don't know what I did in the first place to cause the problem....but keeping my fingers crossed that it stays fixed....thanks for your input...and I hope you have better luck
philwarner
28
07-11-2017 10:21 AM
blackenedindustries
09-30-2015 10:17 AM
