Windshield washer pump, how to test
Put a meter on the connector that feeds it and hit the switch. If you see voltage the pump might be bad. On my 06 STR my windshield washer stopped working but I could hear the pump running when I was connected and i hit the switch. Soooooo if you put a meter on the connector and see voltage it’s most likely the pump motor. if you see no voltage your pump might be good. in my case there was a little filter strainer that’s inside the tank to protect the pump /motor and it was completely clogged with gook. Cleaned it and put it back together
My 06 STR didnt appear to have a check valve at the wiper cowl. Just a hose conneector on the right side behine the hood hing and a TEE on the left side under the cowl and then t2 90 deg fitting for the lines coming thru the cowl.
Where was the check valve?
TreVoRTasmin
02-17-2016 07:01 PM
