Windshield wiper do not work properly
Started today: Wiper works just at full speed and when disconnect, it stops immediately to the position where is it and need exact timing to get it back to the right position. The normal speed do not work at all. If anybody has experience with this, was it faulty wiper motor, wiper stalk or maybe something else? This is a problem which needs to be fixed soon.
I am having a problem with the windshield wipers on my 1997 Jaguar XJ6. They do not work at all when I try any of the settings. However, every time I start the car they do one swipe across the windshield and immediately stop. They then resume the non-working mode and will not move at all unless I turn the car off and restart it. As you can guess, this makes it impossible to drive in the rain at all. Any suggestions would be very greatly appreciated. I have my fingers crossed that it is something that I can do myself because I really cannot afford another major repair at this time. Thank you!
Just wanted to add another note, if it helps others in the future with a non functional wiper.
Fuses OK, relays swapped, relays click, wiper stalk fine, etc. Even went so far as to check the voltage at the connectors and relays.
Turns out, there was actually slight corrosion at the plug connections at the motor which was hardly noticeable. A last minute ditch effort after I noticed a little 'green corrosion' made me try contact cleaner and a paperclip to clean which resulted in a fully operational wiper!
Makes me wonder if there are other connections out there which might need the same treatment....
Jhartz (09-25-2014)
philwarner
09-05-2015 10:05 AM
scottatl
09-04-2015 08:08 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
