Wiper
Received 1,793 Likes
You'll have to remove the cowl cover (its real easy, just 4 or 5 screws) and look at it. It could be either you state, the nut on the wiper is just under the wiper arm cover. I recommend a slight bit of caution with the cowl, as your windscreen washer hose comes up under and through it and the pass through nozzle can be brittle and break. Just so you don't get a little too rambunctious and pull up too hard.
omgimali (11-07-2016)
No, actually I had an issue with my windscreen spray. The line was clogged and it burned out my pump. The nozzles needed cleaning and I had the brittle through connector which snapped when I tried to remove the hose so I could run my nylon electrical snake through it to clear it. I did check the wiper motor and mount while there and cleaned out those dang oak leaves.
The following 2 users liked this post by Highhorse:
ericjansen (11-08-2016),
omgimali (11-08-2016)
