Wiring connector on top of fuel tank
Old 02-13-2018 | 10:09 AM
BW_Hunter's Avatar
Default Wiring connector on top of fuel tank
Hi gents,
I'm having an intermittent problem with getting power to the fuel pump. The problem appears to be the connect on the harness that connects to the tank fitting. The connector has 4 wires...fuel pump and level sensor. I've looked at SNG Barrett and can't seem to find a connector. Can you guys point me to a part number?
Thanks and take care,
Old 02-13-2018 | 10:25 AM
Lady Penelope's Avatar
There is a fuse after the relay and not before . The 4 wire connector is for 2 fuel pumps in a supercharged engine . May have a floating relay as you can swap them if the some marked part #
Attached Thumbnails Wiring connector on top of fuel tank-x308-fuel-fuses-untitled.png   Wiring connector on top of fuel tank-x308-fuel-pumps-ntitled.png
Old 02-13-2018 | 10:33 AM
BW_Hunter's Avatar
here's a pic...its the white connector
Old 02-13-2018 | 10:45 AM
avern1's Avatar
The connector is part of the harness running towards the cabin. Your best source is going to be a wrecking yard or log onto www.jagbits.comand send a parts request with the photo to them. Dan is really good on unusual parts and will get back to you within a day.
Old 02-13-2018 | 10:50 AM
2001 wiring guide shows Brown / Green wire for # 1 pump as the pic is for 1998
Old 02-13-2018 | 11:14 AM
BW_Hunter's Avatar
Thanks very much...I just sent a request.
Take care!
Old 02-13-2018 | 11:21 AM
Have you checked the grounds ?
Notice the difference in VIN #
https://www.jaguarclassicparts.com/u...runk-trunk-lid
Old 02-13-2018 | 11:54 AM
BW_Hunter's Avatar
I did check the grounds and I can make the pump shut down by 'wiggling' the connector. Looking into the face of the connector, one of the terminals looks damaged...
Thanks!
Old 02-13-2018 | 12:17 PM
If you look at the connector do you see any part numbers as mine is X300 and may be different . Pump side look OK ? I think there was a upgraded pigtail that had a noise suppressor in it that may be used and not have to get the whole harness . I could be wrong as this is the case on the X100 .
Seller says will not fit :
Amazon Amazon
See link :
https://www.jaguarforums.com/forum/x...nnector-29178/
Old 02-13-2018 | 02:24 PM
Col. Sandurz's Avatar
I have this in my parts cabinet. Orientation is off obviously, maybe parts would work.
BW_Hunter (02-14-2018)
Old 02-13-2018 | 04:45 PM
yeldogt's Avatar
If the contacts look overheated it may very well be a sign of the pump going and drawing too many amps .... common.
Old 02-14-2018 | 06:21 AM
BW_Hunter's Avatar
Please shoot me a pm about this...it looks like the connector is the same...........Thanks!
Old 02-14-2018 | 06:24 AM
BW_Hunter's Avatar
https://www.amazon.com/OES-Genuine-W.../dp/B001G7XXPU
See link :
Thanks, I'll check it out. The white connector looks the same ...
86jag
05-12-2023 07:06 PM
Hobbo
General Tech Help
01-10-2023 09:03 PM
car5car
08-12-2019 06:33 PM
solerunner
09-28-2011 10:39 PM
NorCalDiesel
11-23-2009 10:15 PM
Quick Reply: Wiring connector on top of fuel tank
