wiring help
I have a short in the steering column adjuster. It is blowing the fuse that also controls the seat switch pack.
The fuse is fine when adjusting the seat, however the second you move the steering column adjuster the fuse blows.
I am looking for help please finding the wiring diagram.
I have the JTIS, but cannot get a wiing diagram to load.... ARRRGGGG.
I am looking for something that will help me trace the wires from the switchpack column adjuster, and fuse...
I want to check the resistance of the wires between the plugs to find the shorted section.
i need the pinouts, etc...
The short is NOT the motor, as everything works when using the memory switches.
driver safz
09-26-2015 06:01 AM
