Won't Crank. Please help!
Hello everyone,
I own a 2000 Jaguar XJ VandenPlas. Recently, the dashboard bulbs behind the instrument panel went dark. I checked the relevant fuses (with the battery disconnected) to see if they were blown but they were ok. So I set out to replace the bulbs and got it done quite easily. The problem was afterwards, when I went to start the car, it wouldn't crank. The lights (interior and headlights, as well as the instrument panel), radio, locks/windows, etc all work just fine when the key is in position "II". But when I go to crank it, the engine doesn't turn over. I don't hear any sounds either. Before I started work on the dash lights, I was sure to disconnect the battery (I disconnected the negative terminal). I think (but not sure) I took the keys out of the ignition. Also, a warning message came up saying the trunk door was open even though I had shut it. I went and checked a couple of fuses but they were all good. After that, the trunk message went away but the car is still not cranking. Any suggestions?
n2audio
17
10-09-2015 11:53 PM
blackenedindustries
09-30-2015 11:17 AM
