Wont start (same story)
Old 10-22-2013, 08:47 PM
Lyndon B Johnson's Avatar
Well i got it started...
It finally sputtered back to life after attempting for the last 2 days.... Pumping the gas back and forth between sputtering and flooding is what got it going..
I haven't cheched the crank sensor yet because i ordered cam seals and will do it all in one shot...
Anything else this marvel of engineering needs while its parked...
I saw something about replacing the throttle body?
and thanks for all of your helps guys, again
Old 10-22-2013, 08:48 PM
Originally Posted by aode06
Your post mentions (same story), can you please tell us of the old story?
I cant find it in any of your post.
I was just saying its the same story as ive read before... xj8/r dies and refuses to start..
Old 10-22-2013, 10:38 PM
Cfraijo's Avatar
I had the same problem. Replaced the Fuel Pump & Exterior Filter. Filter was clogged and I think it might have took out the Pump or weakened over time. After replacing both I had to crank over the engine quite a bit of times before it started. I had the battery hooked with cables to another running car and finally began to sputter and then started. Maybe the gas in the rail was too old. Sat for 6 months.
Old 10-23-2013, 07:04 AM
aode06's Avatar
never ever, do that again,you risk losing your gauges and all sorts of malfunctions in this car.Instead remove the battery and have it fully charged free at your auto parts store.
Cfraijo (11-06-2013)
Old 10-24-2013, 09:46 PM
prostik's Avatar
In my 'won't start' story the problem was with pump as I thought. Replaced pump for new and everything fine again. What's gonna be next? :-)
Old 11-06-2013, 10:13 PM
Cfraijo's Avatar
Thanks for the tip. Will never try that again. Guess I was lucky!
Thanks again...
Wolfy
05-28-2024 08:06 AM
JarodL
03-07-2024 01:39 AM
Bones
09-08-2015 08:34 PM
uncheel
09-05-2015 01:34 PM
David Thompson
09-03-2015 07:48 PM
Quick Reply: Wont start (same story)
