The world hates my car
Received 1,796 Likes
The following 3 users liked this post by AJ16er:
I also did swapping of the glass from a used lamp onto my (broken like yours) lamp. The used one had a good glass bat bad reflector. Removing the glass from the used unit is not easy but it can be done. I cut the reflector (hack saw) into a number of segments right to the glass outer edges and carefully removed them one by one. The glass is actually glued with silicone. After removing all silicone from the reflector of my lamp and from the glass of the used lamp, I glued the two parts together with white silicone (you can use clear also), put a number of strong rubber bands over the glued lamp and left it for a week.
harvest14 (08-29-2019)
I can relate, 5 months sub 1000 miles out of paint, I've already replaced a rear taillight & noticed a couple scratches on the bumper. I do enjoy doing all the washing etc. myself but the thing about new paint is that it doesn't stay "new" for long & you see the degradation up close & personal weekly lol.
unexpected victory
I was looking through some parts boxes even though I was pretty sure I'd sold all my headlights. I was wrong; I found one! It decidedly did NOT look new like the one that broke however. I thoroughly cleaned the outer lens with metal polish and swished glass cleaner on the inside of the lens (blowing it out with the air compressor) and then put the shiny new chrome ring off the new one on it... voila! Still looks older than the others but my net cost for the repair is zero dollars and zero cents. What do you think? Does it look passable or should I spring for another new high beam?
For future reference, a search using carparts.com ...Search Results ...the Carguts place in Blacksburg is where I got my Penta Wheel (excellent condition) for $75 including shipping.
Received 10,876 Likes
I had to replace broken headlights on my X300/XJR so often that I'd buy up good used extras just to have on hand. I did lots of highway travel back then and thrown-up rocks and debris were common.
Did the same for the lousy Alpine/Jaguar radios . Kept a supply of used replacements. I'll bet I had 6 different radios in that car over the years.
chris-jag (09-01-2019)
collector
04-07-2016 03:43 PM
HawaiiRealtor
02-01-2016 10:05 AM
Cambo
08-17-2014 08:54 PM
