wrecked jaguar wont go into neutral!!!
Not knowing the the cars operating ability.
1.requires the ignition key
2. battery charged to activate the relay
Insert key and turn to 2nd position ignition on, press brake pedal to release the shifter lever (should hear clicking sound by shifter) then move shifter to the neutral position.
Hope this helps. Good luck.
