From the XJR in the background, if it has black interior, looking for decent driver side lower seat cushion/cover. Doesn't have to be perfect, have 2" hole in mine now. Thanks!
We have a nice set of complete seats for this car for sale. Here is a link
The one out of the car that you saw in the back looks like this. It has some wrinkles. Let me know if you are interested. You can call me to discuss pricing. 360-773-2632
Windsheild washer reservoir , gets curb damage on the very bottom
Center console lid between the front seats including folding cup holder
Headlght assemblies including connectors with some wire and bracket behind the lenses and the bulbs , used as a poor silvering / bad look upgade for the X300 inline 6 same chassis version 95 - 97
Try to label each of the 4 assembly positions as they as not the same as they fair into the curved sheet metal lines
Z07Brandon ,
You would have to specify the Mod parts as they like myself may not be aware of like oversized supercharger pully diameters.
headlght assemblies including connectors with some wire and bracket behind the lenses and the bulbs , used as a poor silvering bad look for the x300 inline 6 some chassis version 95 - 97
are you requesting these parts or just making more of a general statement about the need for these parts?
Info for yourself and a 2000 is the good AJ28 engine ( Sleaved cylinder walls ) and transmission ( corrected pressure regulator bypassing to shatter / damage the A drum as it comes together
I think the AJ28 has variable cams for more performance above the AJ27 which had its problems and the AJ27 is swapped with the 28 as the customer.
You would need the engine serial # for the buyer
A mod part that comes to mind is a metal thermostat housing and other engine metal uprating away from plastic that didn't do well in service
I just bought a trunk wiring harness from this business last month using ebay. Had a good experience. They answered my questions and the harness worked perfectly.
Thank you so much for those nice words. We are happy to help!
