X308 4.0L gearbox
X308 4.0L gearbox
I recently purchased a 4.0L with a broken gearbox, common issue broken drum inside (i dont totally understand) so also purchased another with a good gearbox so we have swapped them over and now have the same issue but it waa fine in the other car, it drives fine for a couple of mins then comes up gearbox fault and trys too pull away in a high gear (3rd ive been told), if you then turn it off and start up again, it clears for and works fine for a couple of mins again and does the same.
Any ideas please before i have a good 4.0L engine for sale and the rest is scrapped.
Many thanks
Many thanks
