x308 Differential Slow Leak
Well, since you will have the real story on Wednesday, what are you asking?
If you want re-assurement so you can sleep until then, I would say that if there is sufficient oil in the diff case, then this is nothing to worry about on a 15 year old car. If it is low, I would fill it and see how long before it leaked down again. Fixing the axle and pinion seals are going to cost several hundred dollars each, if that is needed. Most leak a little anyway.
Thanks, pretty much just wanted to make sure it wasn't terrible. I can name a few of the moving parts on a car, so I rely on a mechanic to get everything done.
I figured it was good - but hoping it wasn't a reply like "OMG That bottom leak is the deally piston ring O cap - that's 4500 to replace!"
Anyways, off to the store for some wine...to help me sleep
Clayton Webb (10-19-2015)
