X308 differential swap
[I've already asked on the jag-lovers forum, but nobody seemed able to answer]
My XJ8 3.2 is making an occasional knocking sound, noticeable in reverse or when cornering while engine braking. I suspect a knackered diff. (Though I welcome suggestions of other things that may be causing it, especially if they're cheaper and easier to solve.
The X300 XJR has the same 3.27:1 ratio, is stronger and has LSD. Does it make sense for me to get hold of one of these (and how do you fit one with the different input shaft)?
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
You will have to change the end of the diff to a flange type, also the X300 diff is offset whilst the X308 is inline, not much about 25mm, most get over this using a 2 piece prop, to be honest I am unsure if the XJR has a split prop but I do know the XKR has. You will also have to change the front section of the subframe the diff passes through
If the XJ8 has a similar setup to the XK8 which I suspect it does your prop will be a larger diameter made from aluminium, the XKR is slimmer and steel, the problem with the aluminium prop due to its size/offset is it will rub on the tunnel, using the R counteracts this.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
