X308 Gearbox Noise
X308 Gearbox Noise
I have the following noise on my 2000 year XJ8.
click here for sound recording.
Things to note:
1. The noise is only from 1-2 and 2-3rd gears.
2. It doesn't do it 100% of the time (although more often than not).
3. It seems to happen less with a more aggressive throttle or in Sport mode.
4. The box shifts fine in all gears/reverse no clunks and no obvious slipping.
Any ideas?
Things to note:
Any ideas?
Received 1,797 Likes
A rather vague description, but a very common issue with the ZF 5HP is the "A" drum. Let's hope its not that. There are a number of threads on it to include a shift kit fix... https://www.ebay.com/i/373034753894?chn=ps
Barring when the last time the trans may have possibly had the fluid changed, I'd be suspect of a clogging filter and dirty fluid. If you do change the fluid, then I'd also do the shift kit since your right there.
There was once one zf 5 speed gearbox what whined on full throttle during 1-2 gears or gear shift. I cant remember. Otherwise worked like charm. It had fluid changed elsewhere. Fix was another fluid and filter change because level was about two litres low. Turned out that it was filled only engine stationary.. After oil change it has been worked since.
Elizabeth Blake
04-30-2017 03:45 PM
Paultje Panter
04-13-2011 02:53 PM
