X308 Half Shaft Hub Nut Thread
I've got an issue with slight thread damage. I've tried tidying up the thread using a wire brush and a junior hacksaw, but the issue I have now is when I install the correct hub nut, the nut goes 2/3 of the way on the shaft and then the helicoil winds out.
Two hub nuts later and I'm not going to waste my money on a third until I know I've solved the issue. If I can find a hub nut that fits and is one piece it will solve my problem as I can use it like a die. I read somewhere that some of the hub nuts off the older jags are also UNF and fit. So can someone please either let me know what model of Jag has a normal one piece hub nut (not a stupid helicoil nut) that fits the X308 half shaft or tell me what the UNF thread size and pitch is on the x308 half shaft?
innzane
09-02-2015 10:08 AM
