X308 passengers hood latch won't open
1999 XJ8
I see there have been previous posts but wonder if there are any further thoughts or updates. The passenger side hood latch was not working well, but after a few tries if i pulled quickly on the hood release, it would eventually open. Now I can't get it to open at all. Only the drivers side latch releases
Do a forum search for hood release in the x308 forum. You will need to open a hole in the passenger fender arch and release the latch. It sounds like time to replace the cable to the passenger side latch. It is a pretty straight forward procedure and the forum articles have pictures of where to place the hole for access.
rsgensburg (01-05-2016)
good luck! i think most of us have had to deal with that issue! and it sucks but you will get it open...it is all in taking a look at the pics we've uploaded and imagining what things look like when you are poking around...it sounds silly but close your eyes and use the force :-) it took me about an hour to get mine opened when it happened
Interestingly... at the dealership... they just Cut the stud things that lock into the hood latch holes.. I was surprised they didnt use the "secret method" found here...?
mariasm
01-29-2016 10:38 AM
