X308 real left wheel rattle ...
Hi !
My 2001 X308 develoed a much annoying rear left wheel rattle.
Took it to garage this morning, jacked the old smoke up, took the left real wheel off and inspected all visible bushings, NO PLAY found anywhere,
So, now I think it might be some play in the shock absorber top securing AND / OR the big donut "upper spring isolator".
I have been thinking of replacing the donut.
Anyone any idea ? Im my manual, I find: spring upper pan, spring isolator and spring packing ring.
Where does one buy the donut ?
Thanks.
With kind regards,
Takeo.
Thanks.
With kind regards,
Takeo.
Things to check aside from the spring isolator would be the two smaller foam shock mounts up top (foam looks similar to the front upper shock mounts) and the lower shock mount, which is a sort of elliptical bushing. The isolator is available on rock auto, the shock mounts usually come with shocks, and if the isolator is worn the upper mounts probably are as well.
Thank you all for your advice, as soon as I can I will check the parking brake cable.
I do NOT hear any whining ad/or other sound when driving than a very annoying metal to metal rattle even at the slowest speed, for instance when driving over a sewer manhole cover, that is how I found out it IS the left rear wheel. Doing the same none of the other wheels produce any rattle at all.
Funniest of all things is that it rattles even when almost coasting to a stop driving over that manhole cover.
The following 2 users liked this post by aquifer:
motorcarman (05-14-2017),
Takeo (05-15-2017)
Thank you for this advice ! Please not that my hand brake does not really "work", i.e. whne coasting to a stop at a very slow speed, I can pull that handbrake handle as are as I want, it will not really stop the car. Brake linings are ok, though. Also impossible to use the handbrake to make the care "break out" in a turn.
