X308 transmission
X308 transmission
It is my understanding that not all X308 trannys are the same. That the XJR transmission is not the same as the XJ8 transmission. So, having previously heard of X308 transmission problems, is it the XJ8 with the problem, or the XJR, or do both cars have similar transmission problems? Understanding that it tends to happen up closer, or past the 100,000 miles.
Thank you, cheers,
Thank you, cheers,
jaguarVP96
04-22-2016 02:21 AM
Jackson_Dkmg
04-18-2016 07:04 PM
JessN16
04-15-2016 05:27 PM
