X308 Transmission oil & filter replacement
Hi all,
yesterday I've replaced the transmission oil and the oil filter for the ZF 5hp24 transmission that is in my Jaguar X308 2001 3.2L.
The whole process worked like a charm, except that we got out 5,5L of black, old oil and only was able to put in 4,5L of oil - even after letting motor run idle until the transmission oil reached proper temp (50 deg celsius).
As we failed to put more oil in I noticed that the car was not 100% level.
I'm wondering if the missing 1 liter of oil can be accounted for by the lack of level, or is there something else that was done wrong?
Thank you,
bf
Thank you,
bf
To make it even more interesting, the ZF fact sheet about the 5HP24 mentions on page 3 an oil capacity of ~9.9 liter (10.5 quart), so why was it overflowing after 4,5L?
https://aftermarket.zf.com/remotemed...pdfc-5hp24.pdf
motorcarman (06-21-2021)
