X308 wider rear drivetrain
Ive been looking to widen the rear stance of my XJR without spacers and am curious if anyone knows of an alternative axle and lower control arm which is longer than the original? I.E. xjs, xj40 . . Is there perhaps a database that I have not discovered which gives dimensions of various jag rear ends?
The XJ-S rear arm will NOT fit, as it is a totally different shape and is fitted totally different (brackets, 2 shocks with each a separate spring). The Jaguar MK I IRS is totally different to the MK II IRS. The only 'similarity' is the load bearing differential with driveshafts using U-joints.
As the lower arms are also cast on the MK II IRS, it'll be a totally custom job. You COULD though have it a bit differently set up. The wishbones are mounted to a center carrier. This is a cast aluminium 'ring' shape. In this, the diff is mounted as well as the wishbones. You could see if you can get a shop to CNC/mill one/two out of a solid piece of aluminium. Like that you would be able to space the wishbones wider without weld ng the cast iron (which is basically impossible after these many years). But then you'll need to move the shocks and springs outwards. And have some kind of output shaft extension on the diff for the drive shafts.
Just use spacers OR get some widened rims... That is the easiest and probably most effective.
You don't use longer wheel studs if over a 1/4", you use off-set studs. Thus using the existing one's with short lugs. I have them on my Corvette to fit my 11.5 rims. I plan on getting 1/2" spacers (just enough to fill the well), but I need to make sure the front clears the rotation so I don't catch the lip. There is a place in Jacksonville FL (I haven't used him yet) that makes and sells them, he's the Lugman...
Im set on the wheels, will be rolling the fenders. The issue with spacers is you run out of wheel stud. I have the original xjr pentas with slightly wider tires. Ive yet to see a stock xjr with pentas which are close to flush with the body which is what I'm going for especially in the rear as they are inset almost to the point of looking dumb in my opinion.
No you don't. You attach the spacer/adapter to the car's studs with the included nuts and they have pressed in studs that you then bolt the wheels to. As already mentioned above by Highhorse.
https://www.carid.com/1998-jaguar-xj...-78874243.html
The following 2 users liked this post by SteveM:
Count Iblis (03-19-2018),
grandell (03-16-2018)
bfsgross
25
06-13-2010 05:04 PM
