X350 radiator core with x308 plastic tank possible?
Hi guys Time to replace the radiator the leaks is in everywhere
I'm thinking to buy new 2004 xj8 radiator then remove the tank and install x308 plastic tank is that possible? Ist same core size ?
Otherwise I have to buy the junkyard radiator which is not in that good shape
Yup definitely I will take both radiator to the shop but I need to make sure if the size are the same can't do the job by my own though it's not that much difficult I saw they just remove the tank then sealant then pressure test and done
bpwu
02-21-2018 07:55 AM
