X350 wheel sensor on an X308???
Hello All,
I've just had a run in with the lovely wheel speed sensor failure. The codes told me that the front right sensor is shot. So I swapped it to the left to check if the code followed. It did. So the sensor is beyond a simple cleaning. Now its time t replace it.
Does anyone know why the x308 sensor costs roughly $180?
Or better
Does the sensor (same as far as I can tell) for an 03-09 XJ8 fit? I ask because it looks the same but is $120 cheaper.
Has anyone tried to use the X350 part?
Or better
buttpt
03-31-2016 04:48 PM
