XJ - 8 (X308) dashboard lighting problem
Old 11-02-2017, 10:56 AM
rsgensburg's Avatar
Default XJ - 8 (X308) dashboard lighting problem
I have started having a minor problem on my 1999 XJ-8. When I start the car, the dashboard lighting for the right side of the speedometer (middle opening) and the left side of the the right opening - (fuel gauge lights) don't light up well. I assumed it was related to a bad bulb, but after driving around for 10 - 15 minutes, the dash board lights up normally. This just started. Since it eventually lights up normally, I assume it isn't a bulb problem. Does anyone with more understanding of the dash and electronics know what this is and what I should pay for fixing this at my local independent shop? Are the dash bulbs incandescent and if so, should I have all of them replaced if I decided to pursue fixing this? Attaching photo. Thank you.
Old 11-02-2017, 11:42 AM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
74 bulb ?
https://www.jaguarforums.com/forum/x...-lights-55097/
rsgensburg (11-03-2017)
