XJ Sport engine won't turn over
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
XJ sport 3.2 1998
I last started the engine OK a few weeks ago, but now theres just a click (presumably from the starter solenoid). I have checked the battery/connections etc and all are OK (I am an electronics engineer),
so I am assuming that the starter has a problem or the engine has seized with the cold weather, or there is something sticking (film of rust?). I would be most grateful for any suggestions. Thanks.
Chris
Chris
Welcome to the forum Chris,
I'll be amazed if it's is not a failing/partially discharged battery or a loose cable connection at the HPPM (High Power Protection Module).
I've moved your question from General Tech Help to X308 forum. This is the place to post technical questions about your model.
Carnival Kid (12-15-2018)
