XJ trunk will not open
I cannot lift my trunk lid to an open position even though I can hear the actuator engaging when using either the FOB, the release button within the car, or the rear button on the trunk. I even attempted to use my key to open the trunk.
It does appear the trunk releases very slightly; yet, I cannot open/lift it. I can push down on it and then have the actuator lock it tightly again. After attempting (activating the actuator) to open it, I do receive the message on the dash alerting me the trunk is open although I cannot lift the lid.
My guess would be the internal latch itself. This raises the question: how do I get into the trunk since it will not open? Do I somehow remove the rear seat and then will have access to the trunk?
Assistance/Advice is appreciated.
Should this be the solution, I am going to have to drill at that location because after a 1/2 inch in, the screwdriver encounters a metal sheet. Also saw some posts where one measures & drills a hole I believe around the center area behind the license plate. Will check the manual, call the dealer, and then give something a try.
Vector, you mentioned I put my request for assistance (regarding my trunk which will not open) into the wrong forum; yet, you did not inform me as to where I am supposed to put which I will. I put it under Jaguar XJ; but, if there is something more specifically related to the trunk then I am all ears. Thanks.
The Jaguar XJ sedan was originally introduced in the late 1960s. It has run continuously since then as updated models.
https://en.wikipedia.org/wiki/Jaguar_XJ
bob
bob
Try that forum and you will get better results.
Vector"
I suggested you put it in the X350 forum, see above. The 350 is, other than the look, a completely different car than a 308, so our advice here won't work for you, that is why you are hitting a metal plate that is not there on a 308.
Vector
