XJ (X308) Shifter Components Information
Hi
Here are 4 PDF files I created from the JTIS21 Jaguar Repair Manual that cover the description of operation, the components, and the removal & install instuctions & illustration for the Transmission Shifter (Driver Gearbox Control):
XJ (X308) Transmission Shifter system components.pdf
XJ (X308) Transmission Brake Shift Actuator Adjust.pdf
XJ (X308) Transmission Brake Shift Interlock Actuator Adjust Override.pdf
XJ (X308) Transmission Selector Lever Cable Adjust.pdf
Jim Lombardi
Jim Lombardi
Hi
Here is a DIY video on youtube.com on removing XK8 center control that forum member Rev Sam created:
Jaguar XK8 Center Console Removal - YouTube
Here are 3 other forum threads that deal with the removal and install of the finish panels (that need to be removed to get at the shifter components):
https://www.jaguarforums.com/forum/x...r-i-faq-65903/
Look at post#1 - lists a bunch of PDF - there are 3 pdf files you want view (Selector Level and the 2 floor consoles PDF files).
https://www.jaguarforums.com/forum/x...-errors-61137/
https://www.jaguarforums.com/forum/x...uctions-46361/
Jim Lombardi
Jim Lombardi
n2audio
17
10-09-2015 10:53 PM
