Xj40, x300 and x308 suspension and bushings different?
Old 03-23-2016, 11:09 AM
Col. Sandurz's Avatar
Default Xj40, x300 and x308 suspension and bushings different?
Im finally about 80% of the way done with brakes. New hoses for rears and basically the entire system is new.....
I'm looking at replacing the last few bushings in front and rear of my 2001 SVP. I know the suspension stayed mostly the same between these generations. Some parts seem to be easier I find in other models. So question: what parts are same/similar between them.
Example, A-frame bushings for XJ40 and x300 is CCC6875, the x308 number is MJA2595AC. They seem similar, are they compatible? Would help to know if I look for poly or other bushings as I get into this.
Old 03-23-2016, 11:58 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
The rear axle is except for the tube brace identical. The front axle is TOTALLY different. No parts are the same. Bearings and bushes are not identical.
al_roethlisberger
06-17-2024 08:56 AM
metalmarty
03-12-2016 10:29 PM
RichardPhuket
03-03-2016 09:44 PM
kiwijohn
General Tech Help
03-03-2016 12:54 PM
jacktoth
02-29-2016 04:49 AM
Quick Reply: Xj40, x300 and x308 suspension and bushings different?
