XJ8 2002 SatNav
XJ8 2002 SatNav
I have purchased a Sat nav from a 2002 XJ8 , all connectors were in my car but when I press the sat nav button on the head unit nothing happens .The unit is powered ok and the CD player selects correctly so as it passes through the Sat nav unit the connections are ok.Do I have to enable the head unit in some way to enable it to see the sat nav unit ? has anybody else retro fitted a sat nav unit to their XJ8.
The car had all the wiring in place including the anntena , I just plugged the unit in - 2 multiplugs at the rear ,the anntena , and a link cable which i took to the sat nav then on to the cd multi-changer.
You should have more than one antenna. Radio and GPS. The GPS antenna cable is a Gray GT5 Coax like DBX mentioned.
It might help if you explain what you bought and installed. I have a factory NAV option and can at least verify that you have what you need
@haysmuir
I hope others on here can get you going, but I hope that you didn't spend a lot on getting the sat nav because it is trully bad.
Have you used the sat nav in this model XJ before ?
I'm worried you're going to spend a lot of time and effort and money to get something that is about 10 years behind a 100USD portable GPS (TomTom, Garmin, etc)
I have the SatNav in my '00 XJR and here is a list of issues, all of which are addressed fully in even the cheapest portable GPS units :
1. The map disks are now at least 6 or 7 years old, and there are no new updates for them, so if you live in an area with any construction, chances are you're going to have errors in the maps
2. It's chronically slow at routing. Mine takes around 30 seconds to do a 10 mile journey (My TomTom takes around 3 seconds)
3. You don't have a good visual display, it only uses the radio display which is A) tiny and B) far too low down in the dash for you to safely look at it. It also only gives arrows, which is nothing like as useful as a 3D map thats standard on all portable GPS units today.
4. I can't get mine to do auto-rerouting (if you get lost or go off route) This may be operator error but there is no mention of this feature in the documentation, and once you go off route, it gets stuck and you have to cancel and restart the route. (TomTom and others reroute instantly)
5. Data entry (street names, etc) is painfully slow as you have to use a scroll wheel action (Kind of like those funky label printers you used to get ages ago when you turned the disc, stamped the letter, then turned to the next letter, etc)
To be fair, the built in system does have the advantage of using the cars audio system, and muting when needed, and also you don't need a screen and mount stuck on your windshield obscuring your view but in terms of usability, I just can't accept the shortcomings.
Maybe other users have had a better experience but I think once you've used a modern quality personal GPS it's difficult to get along with the Jags SatNav
SARC is right that the NAV in those years is a bit primitive compared to what is available now. But the truth is it works and works fine. Maps are a bit old, but it gets you there. I have never known it to take too long to calculate the route and it gives good direction and easy to understand. I don't like the fact you can't program in a destination while the car is moving. Here in the US we like to multitask while we drive.
Having said that I also agree that I would not go to great lengths to get the factory NAV from 00 - 03 working in my car, but since it came from the factory already installed.. I like it.
Nav
I retrofitted a nav system in my 01 XJR and I guess that I'm the one that discoverd the need to wakeup the system.
I do have the disk.
I'm kind of surprised that all the wiring for the nav was in your car, on mine i had to instal it.
Which specs ( USA, etc) is your car ?
Luc.
PS: yes the factory system is pretty basic but
do the job
I do have the disk.
Luc.
do the job
Despite some of the other posts, this is a good system in my opinion. OK, so there are no 3D colour maps, but I find that spoken instructions are more than adequate to get me where I want to go.
Have you actually fitted a GPS antenna to the car, although all the wiring is in place, it's highly unlikely there is an antenna fitted to the other end of the cable. To check, you'll need to remove the rear parcel shelf as this is where it will be fitted.
Where did you get the unit from? I bought one off ebay earlier in the year from the States as a spare, but it was faulty and had the same symptoms as you describe.
So you installed a NAV head unit and the rear trunk mounted DVD unit with map software. I assume pressing the NAV button does nothing.
Where did you get your navigation system? I have a 98 VDP and would like to upgrade but would prefer stock.
Thanks,
Bill
UKnFor-dluv-expat
09-26-2015 08:40 PM
jessejamestw23
09-26-2015 03:57 PM
zdrapec
09-25-2015 05:49 AM
