XJ8 2003 MY Differential
Received 3,905 Likes
RE: XJ8 2003 MY Differential
Joey, odds are, you will need to use a vacuum pump or other similar device to remove the fluid. This device can be picked up from any auto parts store for around $15. Other than needing the vacuum pump, the rest is really easy. I think it took me about 30 minutes to do the rear differential on my X-Type.
Received 2,192 Likes
Drain plug in the bottom? Do I have to remove the plate to find it? The only plug I seen was the back. I looked in the hole in the plate and no plug, this is why I ask.
ORIGINAL: BRUTAL
drain plug in the bottom, and fill plug in the back...fill till runs out the back hole and then close back up, and dont crank it, it only takes a snug
Ipc838
09-13-2015 03:27 PM
kabs3012
09-12-2015 10:40 AM
