XJ8
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1081x619/na_4_0_lit_5bce37e30b814524f91f224f487e94ebdebf6cfc.jpg)
It is LWB, I have one (the rear door windows are considerably longer than the front ones).
In general, it would be good if the seller can show you the maintenance history. Otherwise, if not already done, you will need to replace the chain tensioners and guides, the water pump and the thermostat as a bare minimum.
As for a test drive, the bare minimum again would be to to verify that the engine starts easy, sounds smooth, it is not overheating and that the transmission shifts well (smooth). I'm sure others will provide further advise.
Ihab (05-03-2021)
04XJ8
16
09-18-2011 11:11 PM
