XJ8 3.2 Auto
XJ8 3.2 Auto
Hi, new here, just got my XJ8, sorting out problems, can anyone help on this........
i have to wait a while, when putting my foot on the brake peddle to move the Auto shifter into position, reverse / drive. I can here a switch or something clicking, which then enables me to move the shifter into position.
can anyone tell me where the switch is, how to change or adjust it.
thanks for any help Jagger98
Shift interlock solenoid is bolted to the side of the trans shift mech. You will need to remove the shift bezel (a credit card type tool) and the 'ski slope' surround to get at the part. Now you know the names of the parts, use the search function as there's deep knowledge and plenty of posts on this subject.
yes you can, however I took the radio console out, you might be able to do it in. Sorry if I am repeating info already on here, I hope this is helpful
thought might be interesting to have a pic from underneath.
just undo the two nuts, 1
& 2
slip the link off the pin
Mine is the large hole type, I knocked out the pin on the old/new one and changed the link over
& 2
Ok Fitting the Switch, I thought a while, decided to save my back, so I took the front drivers seat out, laid somethiung to lie on, removed the 4 TORX bolts and disconnect the wiring under the seat.
Seemed easier to get the seat out the back door, did get somone to help, had to swing it out.
Undo the nut and bolt, remove while resting your head/arm on the brake pedal, a little fiddly, slide out switch, you can then see the location guide at the top.
That's it, fitting is reversal, while leaning my head on the brake pedal with some pressure slide the brake switch onto the guide properly, its all done by feel, you cant see it, well I couldn't anyway. Then put the bolt and Nut back on, CHECK which way the bolt was when you take it off, I nearly forgot, and I only did it 10 minutes before, gently let the brake pedal back, locating inside the switch.
Once it was fitted I check the shift/ Gear stick went into Reverse and Drive before I put the seat back, it worked. Put the seat back in, in all it took me about 2 1/2 hours from start to finish, gave it a test drive and so far it has not refused to go straight into Reverse/Drive. It make me wonder weather I needed to replace the S.O.L.E.N.O.I.D at all, maybe I should have started with the brake switch first, either way new they are both expensive £200/250(S.O.L.E.N.O.I.D)£100(Brake Switch - from Jaguar).
I did use a used S.O.L.E.N.O.I.D to replace my original at £10 to check if there was any difference, shown above at the beginning of this post, glad I did, otherwise I would have been kicking myself at £200 sov’s.
James_W
04-30-2018 08:40 PM
