XJ8 3.2 has a slight " Cough "
Good afternoon all , hope someone can shed some light on this.
Vehicle idles nice and smooth and runs ok , however, Ive noticed that if its idling and you put the foot down to rev it , it has what can only be described as a slight "cough" before revving as it should , any ideas/thoughts?
HarryGilfillan (12-02-2017)
Had the same issue with my last 308 before I bought it. Once purchased, Cleaned the MAF, the throttle bore and plate and made sure the air duct was tight -- issue resolved. I think cleaning the throttle bore and plate did the trick. New plugs, air filter, and secondary tensioners, later.
