XJ8 Aerial Help
Hi All.
Looking for some help please if possible.
I have just bought a immaculate 1998 XJ8 4ltr Sovereign and I love it.
After reading the Manual it says that the ariel should go up and down with the radio on-off button.
My ariel motor operates on the ignition on-off, IS THIS CORRECT?.
At present my ariel is stuck on the fully up position and does not go down.
I bought another ariel with the plastic notched cable and was going to install it but I am now just wondering if its a stereo issue as the stereo On- Off is not operating the motor.
Has anyone had this issue before?.
Many thanks Scott.
Many thanks Scott.
I had a very similar problem when I bought my XKR and the aerial wasn't working. The previous owner was convinced it was the motor which is the whole unit and so sold the car as is.
The aerial is supposed to operate when the stereo is switched and goes down when the stereo is off.
People told me the problem would just be the mast either bent or problem with the plastic wire inside the mast that pulls and pushes the aerial.
By pure chance I twisted the mast from side to side and it all working again.
Just thought I'd mention it.
Regards
Rocky
Regards
Rocky
Hi Rocky thank you fir your info.
Rocky do you remember the actual radio on-off operating the motor.
I only hear the motor for the ariel operating with ignition on-off .
I have bought another mast, but will turn the existing tomorrow to see if it works.
Thanks Scott
Thanks Scott
Regards
Rocky
Regards
Rocky
Welcome to the forum Scott,
I've moved your question from General Tech Help to X308 forum. This is the place to post tech questions about your model.
The aerial should raise/lower with the On/Off button.
Thank you Graham.
I will check again tomorrow regarding the Radio.
Hopefully the new mast and plastic geared strip will resolve this.
I may be back soon if this doesnt work, i appreciate your help with the info and correct area to list onsite.
Scott
Scott
Mine certainly goes up and down with the radio on/off, as well as actual ignition (which basically is turning the radio off). It leads me to think that the output signal from the radio to the antenna motor isn't working properly, though I'm not sure the wiring on it. Doesn't sound like the antenna itself is the issue though.
Ok thank you for your help.
QUOTE=CharlzO;1360232]Mine certainly goes up and down with the radio on/off, as well as actual ignition (which basically is turning the radio off). It leads me to think that the output signal from the radio to the antenna motor isn't working properly, though I'm not sure the wiring on it. Doesn't sound like the antenna itself is the issue though.[/QUOTE]
My 2000XJ8 just had the antenna refuse to go back down.
Has always worked properly for 16 years, up when turned on either CD player or radio & went down when turned off or shut off car.
I was picking up my car from an auto upholstery place that recovered the cracked vinyl armrest (They removed & replaced driver door panel to do this) & my antenna was up! Would not go down. The shop owner was nice & said he turned on radio to verify the door speaker still worked after reassembly & antenna would not go down. I was distressed & thought but, did not say, that they had somehow caused this problem by messing with the wiring. I’m not a big believer in coincidence. He said to take it to my mechanic (Jaguar dealer) & if the mechanic thinks they could have caused the antenna problem by removing door panel he would make it right or words to that effect. (I.E a “Soft” promise to pay for repairs IF he was at fault)
Note: had this happened b4 I took it in, I would have simply thought the car broke & gone here to JF to research & found this thread & moved the trunk liner away & discovered the issue & ordered part from aftermarket or from Jaguar & fixed it myself.
Jag SA said motor good but cable broken so repaired/replaced $151.14.
Invoice says “Replaced broken Antenna mast” LNA4134AA
$65.50 part
$80 Labor
T= $145.50 + tax
So, it now works once again. Although it makes noise as goes back in.
Jag SA says he cannot see any way the upholstery shop caused this since it is mechanical, I agreed. So, it must have been a coincidence.
I just now looked up the part & Gaudin Jaguar sells online for $53.21 + high S&H
Amazon: Uro parts $16.41
I would have purchased from Amazon & saved ~$130 & DIY
$65.50 part
$80 Labor
T= $145.50 + tax
It’s unfortunate you thought that it wasn’tcoincidental and had your aerial broke before you took the car to te upholsteryplace I’m sure you would have gone down the cheap route.
I understand that the aerial masts not sole byJaguar are just third part. Some sellers claim they are made by the same aerialmanufacturer but I’m sure there’s lots of cheap poor quality ones out there. Soat least you have piece of mind it’s a Jaguar part.
My aerial makes a noise when it goes back in,clunking etc but it’s worn out and sometimes doesn’t go all the way back unlessI twist it a little bit. I wouldn’t expect a new one to make a now.
Depends how fussy you are
Regards
Rocky15
Regards
Rocky15
Received 1,796 Likes
I eliminated my aerial not because it was broken, but so I wouldn't forget going through a car wash and I thought it made the car look outdated. So a few years ago I did this....
https://www.jaguarforums.com/forum/x...ve-one-103359/
...be sure to prompt the pics to see the unit because it blends so well with the window its difficult to see. I almost solely listen to SIRIUS anyways, but if I want to hear a local station, I have it.
Rocky15, Yeah, I’m picky. I will make Jaguar fix the new noisy antenna in a couple weeks when I have time to bring it back to them.
Vector, I had seen the thread about the switch when searching for antenna issues. Great idea. My antenna never bothered me.
Rarely listen to radio, just CD player so antenna going up & down is not necessary. If I knew about this switch soon after I purchased the car in 2000, I would certainly have done the mod! Just to preserve the antenna from eventual failure & wear & tear on the motor & cable from retracting daily. Now my Jag is not my daily driver. I bought a new car last year.
Highhorse, I never used an automatic car wash for my Jag. Always have washed it by hand. When I did use the radio, it was to listen to AM talk radio so the worse reception on those hidden antennas would not have worked for me. Have the multi CD changer option so, 6 CDs at a time for music for me. I know this is dated now![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Great job on your installation & photos in that other thread, BTW.
I was told once although I don't know much about them, is that a Jag is like a washing machine. If you don't use it the parts go faulty from no use. At least if you do use one regularly and they break at least you've had some use out of it.
Took the Jag out at the weekend, my windows are half a sleep working very slow and the aerial couldn't get it's end up.
