XJ8 Antenna replacement - so easy?? Need help
Old 09-05-2009, 03:55 PM
EZfan's Avatar
Hi 2jag. Last week, I did remove the antena nut out from my VDP to polish and it came off easily. Don't know why yours is stuck but make sure the right nut is the one just on top of the car's body on you last photo. Godd luck.
Old 09-06-2009, 04:53 AM
chupacabra's Avatar
first of all take the all asembly ot of the car, if the bent antenna stops you from taking it out of the car just cut it ( you're changing it anyway) and you dont have to loosen the upper nut to take it out , it just pops out of the rubber sealing. (hope you'll understand what i mean )
then you should take apart the black plastic part (you'll have to do it anyway) and so you'll se what is the best that you can do... mine antenna is the same as yours ( don't know if others are diferrent) and once I forgot to turn of the radio in the car wash , it broke, but I didn't change it, just made it shorter ad it works fine. good luck!
Old 09-06-2009, 12:01 PM
Markus's Avatar
Detailed write-up here: http://jeg.serverhouse.com/Jag_docs/ may be of substantial help.
________
Old 09-07-2009, 01:00 AM
dougs02's Avatar
The nut is probably just stuck in the rubber grommet. Grab it with something and pull up on the nut. After the nut is loose, have someone turn the ignition key to run and pull on the antenna mast, it should come out along with the plastic tape that runs it up and down. Insert the new tape, watch for the correct alignment of the tape and have someone turn the ignition key to off. The antenna motor should pull the tape and the antenna in place. Apply a little lube, I use silicone grease, in the grommet so the nut slides down and turns easily. I have installed more than a couple until I discovered my wife was starting the garage door down before the car was completely in, bending the antenna mast back, and this procedure has always worked for me.
Doug
Old 02-08-2011, 07:02 PM
johnny_kiu@yahoo.com's Avatar
where you get your replacement antenna? My is broken off by flying Ice sheet from the top of a van.
Old 02-08-2011, 07:14 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Go to the vendors section of this forum https://www.jaguarforums.com/forum/vendor_directory.php or ebay
Old 02-09-2011, 05:25 PM
avt007's Avatar
See this post, I
just replaced mine. https://www.jaguarforums.com/forum/s...t=48388&page=2
The last post has the correct part.
JarodL
03-07-2024 01:39 AM
jehart49
09-12-2015 05:36 PM
KarimPA
09-03-2015 07:32 PM
OkieTim
09-02-2015 12:48 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: XJ8 Antenna replacement - so easy?? Need help
