Xj8 auxiliary water pump
Are you sure the pump is broken? Just asking as while a common problem on these cars, clogged heather core is another. I also thought my aux pump was dead and bought another one. To find out the one I had worked just fine and just needed to flush/backflush the heater core. Which is what I need to do every winter (it's just about that time again....). Cheers
What coolant are you guys using?
I don't understand all the cooling system problems ... I can see how it may have happened in the earliest cars that switched coolant .. but by 2001 they were all using the newest products?
It's so important to stick with the correct fluid -- and keep the system filled.
I believe the pump is made by Denso -- that's not to say that others are not selling a rebadged version.
Thanks. Upon further review, I'm going to leave well enuf alone.
Had suspicions about the aux pump for a while. Did a clean/flush/new (then a tstat, then water pump, and 1 new bleed tube), and it seems to be working ok. Not true winter yet, so we'll see then.
Now, about the door handle....
Thanks,
Lowell
Thanks,
Lowell
FS[MidWest]: 2000 XKR parting out
julesjag1
41
02-28-2016 04:48 PM
FS[NorthEast]: for sale 2000 XJ8
jrb53
11-06-2015 08:00 AM
