XJ8 brake lights stuck on when car is started
nemesis1109 (06-28-2020)
Sounds like it is time to replace the brake light switch. Look under the dash at the pedals. Is the brake light switch extended? It is possible it has come lose and needs to be adjusted. It is a normally open switch and closes when the pedal moves away from the switch. If the pedal isn't touching and pushing the plunger in when at rest it may have come lose and is out of adjustment. If not the switch has gone bad. Do an advanced search for brake switch on the x308 forum and there will be lots of info for repair.
Don B (06-29-2020)
annamiata
12-08-2019 02:56 PM
Austone
09-20-2019 08:00 AM
josh_77073
12-17-2012 10:48 PM
Navionsam
05-21-2012 04:37 PM
