XJ8 Burning Oil or Oil Leak?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
My XJ8 is Burning Oil or I have an unknown Oil Leak? When parked in the garage, I don't see any oil leak on the concrete. But if I go out on my job which is about a 220 mile round trip it will burn almost a half to full quart of oil. Any suggestions where it could be leaking from?
It probably isn't leaking if you don't see any oil. Try disconnecting the partial load breather near the front of the left bank and cleaning the port with a 3/32" drill bit.
Burning that much oil could destroy the cats, so come back if that doesn't help for more suggestions.
PART-LOAD BREATHER CLEANING Photo Gallery by Max Heazlewood at pbase.com
How do you open up partial load breather or pull it out because it doesn't want to come out and I didn't want to break it? I tried turning it and pull up but it still doesn't want to come out. Do you take some needle nose pliers and try squeezing the sides to open it up? Or is there another way?
What viscosity oil are you running? If the outside temperature is 90 or 100F, and you are scooting along, a thin oil might be getting past the rings. If it doesn't drop below freezing where you are, 20w-50 might cure, or reduce the oil consumption. Then if you really like the car, just factor it into the running costs, and check it every day.
I don't want to hijack this thread, but I am having a similar issue, burning or leaking oil, however not at that rate. I live in Wisconsin, so cold winters and warm summers (I do a lot of driving). So far we have had a lot of 70-80 degree days, and it seems like this is when I smell burning oil the most. Would changing to a heavier viscosity oil remedy this issue somewhat possibly?
Would it be unsafe to run 10w30 or 10w40 rather than the 5w30?
I use full synthetic oil also.
FWIW, my Jag has been very good at not burning oil. I did have a leak once. I could smell oil burning off of something when I parked the car. It turned out to be coming from the oil filter coming a little loose. That may not help you guys much, but my bet would be on a leak. If the valve covers have been off, someone may have over torqued them and warped or cracked them. Also, don't top the oil off unless it gets down to the "add" mark. The car might like to stay at 1/2 or 3/4 down from the full mark.
aholbro1
08-05-2021 05:02 AM
