XJ8 Eaton M112 questions
Old 06-29-2018 | 08:42 AM
Mykk's Avatar
Originally Posted by AZjag1999
You mentioned that the "early set of manifolds that appear to fit A-Ok with the Gen V inlet," I was referring to that.
They appear to fit well and I'm going to run with them as is, unless a hurdle presents itself down the road I'll then address whatever problem may be.
As for the fuel injectors: "AJ26 XJR/XKR injectors flow 355-360cc at 43.5PSI. AJ27 injectors 5-10cc more." From "https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/fuel-injectors-118096/"
Originally Posted by XJR-99
AJ26/AJ27 SC: 360cc at 43.5PSI
Thank you, those injectors may be pushing their limits on this build. I'll run them for now and see if they present and issue later.
Old 06-29-2018 | 12:18 PM
XJR-99's Avatar
They have been used with FPR up to 570hp .TS setup.
Old 01-03-2019 | 07:11 AM
Mykk's Avatar
....as I was moving along with the project I think I'm going to build a little old school hot rod Track-T roadster kit car for it and use the BMW 6spd manual.
Yeah, ended up going that route.
The following 2 users liked this post by Mykk:
Badbenz94 (01-11-2019), Sean B (01-03-2019)
Old 11-28-2022 | 09:05 PM
Eternalightwithin's Avatar
Default Question about this mod
Originally Posted by Cambo
There are (basically) three different supercharger/intercooler setups;
4.0L XJR and XKR
4.2L XKR
4.2L XJR, S-Type R and XF SV8
The 4.0L XJR/XKR system looks very much the same as the 4.2L XKR, but the lower manifold is different as you see in your pics. Looks like you've got them mixed together.
The 4.2L XJR, S-Type R and XF SV8 is a totally different arrangement, not the one you want.
I'm following in Mjyk and other footsteps. I see that the 4.0 Jag Eaton and intercoolers have to stay together as well as the 4.2 pieces. Did we ever figure out if the 4.2 Eaton fit the BMW 540i or did the intake flange not line up correctly? If this is right then the only option is to pull a Eaton and intercoolers off of a Jaguar 4.0L?
Sincerely,
David Piel
Old 11-29-2022 | 11:19 AM
Addicted2boost's Avatar
I’m not a BMW guy but, I seem to recall another conversion guy on here asking questions about his. I *think* he had to have adapters made to make his fit. Search on here BMW & supercharger.
Old 11-29-2022 | 07:16 PM
David N. Warner's Avatar
That is fantastic! Really appreciate you showing it off!
Old 04-10-2023 | 03:42 PM
SamsX5's Avatar
Default Advice
Hello Mykk
I’ve been looking at your forums and YT channel about this build. I know it’s been a few years since.
Is there anyway I can contact you to ask for Advice on the BMW M62 with the M112 Eaton SC build as I’m currently starting mine
thanks Sam
  #28
Old 10-10-2024 | 12:35 AM
Jaxkson's Avatar
Default M62 Build
Hello Mykk,
Just checking in on you to see how your build is preforming and is there anything you would do differently, and last do you have any advise for me? on my which is going to be the same as yours.
Thanks. Jaxkson.
Old 10-10-2024 | 05:19 AM
He hasn’t been on here since 10/15/20. No telling what the conclusion was.
80sRule
06-27-2016 09:57 AM
Newby
06-06-2012 12:18 AM
avos
05-28-2012 06:07 AM
RealmCenter
01-11-2012 05:21 PM
super_jag
23
04-11-2011 02:00 AM
Quick Reply: XJ8 Eaton M112 questions
