XJ8 electrical problems
You need to see if you have power to those fuses: I am guessing not, so go back and check the wiring to and from the battery and alternator. You left some wire unconnected. Also, grab a wiring diagram (up in the STICKIES), and see if a relay is involved.
Not those, then check the bulkhead wiring studs on the right side as it passes through from the battery to the fuses.
got it , it was some bad fuses that I missed thanks
