XJ8 front disc size?
Correct. There are two sizes of disc on this model.
Generally the 325mm is fitted on vehicles with R performance brakes and the smaller 305mm on standard but you should check the actual diameter of the discs on your vehicle before ordering.
As an added complication, they are also available plain or cross drilled!
Superman001 (02-12-2014)
Mugatu
22
06-23-2020 01:50 PM
